Perform this procedure to disable Auto-sense on one or more ports. You also have the option to disable Auto-sense on the port but retain the configuration that the system applied dynamically. The dynamic configuration becomes a manual configuration and is visible in the show running-config output.
If you select more than one port, the format of the tab changes to a table-based tab.
You can also complete this task on the Configuration > Fabric > AutoSense > Port AutoSense tab. For more information, see View or Modify the Auto-sense Port Configuration.
